Question about La Crosse Radio Controlled Atomic Clock
I want instructions for setting time and date on an Atomic, Radio Controled wall clock ( La Crosse Technology Model WWVB (0) no jewels unajusted MADE IN CHINA Clock has run perfectly until batteries ran down. After inserting new batteries, one AA and 2 AAA, time was set automatically but small window for day and date remains blank
3 Suggested Answers
SOURCE:
homedesigner
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
gopakumarg43
  • 76054 Answers
SOURCE: my La Crosse Radio controled
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
Posted on Jul 31, 2011
Cannot set time
WWVB Radio Controlled Clocks
www.nist.gov/.../radioclo...
National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
[PDF]Atomic Analog Wall Clock - La Crosse Technology
https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
ICF-218 Sony Alarm Clock - YouTube
? 1:50
https://www.youtube.com/watch?v=XTQ8zEMMNq8
Aug 4, 2012 - Uploaded by sohvintage
Jan 10, 2016 | Audio Players & Recorders
How do I change to daylight saving time?
Your clock may have failed in a way that new batteries won't help.
Apr 04, 2015 | La Crosse Technology Atomic Wall Clock -...
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
Mar 16, 2015 | La Crosse Technology Black Model Wt-8005...
Www.lacrossetechnology.com/8248 need to reset time!
I'm not totally sure what you mean by "reset the time" because the unit normally sets the time automatically from the WWVB radio time signal. If you want to do it manually, this is what the Instruction Manual (PDF format) says:
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
  1. The hour digits will start flashing in the upper LCD.
  2. Select the desired hours by pressing and releasing the + key.
  3. Press and release the SET key to advance to the minutes setting.
  4. Now the minute digits will start flashing.
  5. Select the desired minutes by pressing and releasing the + key. If the + key is held, the units
    will increase by 5.
  6. Press and release the SET key to confirm the Time setting and continue to the Year setting.
Nov 08, 2012 | La Crosse Radio Controlled Atomic Clock
My La Crosse Radio controled atomic clock is spinning for the last two days, How can this be corrected? I have a secound Clock same modle it is working fine. Modle# wt-3102
Hello
Ok.
Jul 31, 2011 | La Crosse Radio Controlled Atomic Clock
We now have two wall clocks that have stopped. Replacing batteries has not worked. Are they repairable? Can we get new or reconditioned movements?
Hello
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal.
Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio-
Controlled clocks and other electrical appliances that cause interference.
Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal.
Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com).
Daylight Savings Time
The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La
Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall.
Arizona and Indiana
If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
Mar 14, 2011 | La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
My WWVB radio controlled quartz ch 899 clock is 21 minutes off the correct time. How do I set the clock by minute intervals?
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
Jan 12, 2011 | La Crosse Radio Controlled Atomic Clock
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
We have an atomic clock with calendar and temptature on it. We changed the battery and it is now on Eastern time zone, not Pacific time zone. How do we set it? It is La Crosse Technology Radio Model #...
Feb 20, 2010 | La Crosse Radio Controlled Atomic Clock
La Crosse Radio Controlled Atomic Clock Logo
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
