Master
- Posted on Sep 25, 2010
Re: Pot only filling half way
If pot used to fill all the way then check the filter if one is installed and the restrictor on the back of the tank, you can also run the deliming spring through the brew tube.
If the pot never filled all the way then remove the front panel and use the instructions to reprogram the brewer.
