HI- Washer really don't have a lint filter so to speak. Some of the front load washers have a filter in the drain pump but that basically just keep the quarters and bobby pins from ruining the pump. Is it possible to have someone extend your standpipe with a larger diameter pipe that you could place a screen into, or place the screen on the drain hose and then put them both into the larger pipe. A plumber should be able to figure something out. It would be about $1000 dollars cheaper than buying a front-loader and probably more effective. Good luck.
Testimonial: "That's kind of what I thought of doing. Thanks so much for your input."
