Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
Electronic Oven Control won't work after power failure
I was using my oven when I heard a bang and the Electronic Oven Control (EOC) went blank. I went downstairs and the breaker had switched off. I turned the breaker back on, and the EOC had power, but the clock was flashing and the code flashing was PF. This PF code often flashes once the power comes back on after a power failure, but this time when I press any of the buttons on the control panel, nothing happens. The manual says to press the clock button for 10 sec, then it will beep and reset, but nothing happens. No buttons work. The gas cooktop works and the warming drawer works. It's just the control panel and the oven that won't work. Any thoughts? HELP!
  • 2 more comments
  • Leigha99 May 22, 2008
    thanks
  • Anonymous Sep 15, 2008
    i have the same problem
  • Anonymous Feb 27, 2009
    I need help with the same exact problem...
  • Anonymous Apr 03, 2009
    I have the same problem, but i want to make sure before i change the EOV that the next one won't do the same thing.
  • 869 Answers
Replace the clock.
Posted on May 22, 2008
  • 45 Answers
The pf=power failure
try unplugging unit for a few min then try again, but you may have a bad control
SOURCE:
What does fault Code F1 mean
The "F1" fault code usually indicates one of the following possible failures:
Shorted keypad which is part of the Electronic Oven Control (EOC)
or a
Failed Electronic Oven Control (EOC)
Oven temperature sensor is bad (this is located inside the oven cavity at the upper left rear corner). The oven sensor should be disconnected and tested for resistance and compared with the "RTD" scale.
You can try resetting the range by disconnecting it from the outlet or switching off the circuit breaker of the home for 10-20 minutes then restore the power. If the reset doesn't work your range may have one of the above failures.
Sep 22, 2017 | Kitchen Ranges
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Kenmore oven giving F1 error code. Oven not working, but stove is working.
The "F1" fault code indicates one of the following possible failures:
  1. Shorted keypad which is part of the Electronic Oven Control (EOC)
  2. Failed Electronic Oven Control (EOC)
  3. Oven temperature sensor is bad (this is located inside the oven cavity at the upper left rear corner). The oven sensor should be disconnected and tested for resistance and compared with the "RTD" scale.
Jan 21, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Error message F!0 displayed
F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Sep 23, 2010 | Frigidaire FEF366DC Electric Kitchen Range
Quatre par convection Erreur auto Frigidaire Nettoyant f 3 et f 1
F3 -The oven temperature sensor is open
Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
F1- EOC (Electronic Oven Control) failure
Replace EOC (Electronic Oven Control)
Thank You
Sep 03, 2010 | Frigidaire Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error code 065 jjj jjjj jjj 065 (frigidair Model feb398ceb)
2 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace F2 Oven too hot Check Bake function F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F4 Oven temperature sensor shorted Replace component F5, 6, 7 EOC (Electronic Oven Control) failure Replace component F8 Lock switches Check or Replace component Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control) F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control) F3 Oven temperature sensor open Replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control) Version 4 Failure
Code
Condition Check/Repair F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Nov 18, 2008 | Frigidaire Kitchen Ranges
F6 f8 and f12 error reading on stove
F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Oct 27, 2008 | Tappan TGF320 Gas Kitchen Range
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
1,406 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
