Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there’s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 — Atlantic Time ZONE 2 — Eastern Time (Default Setting) ZONE 3 — Central Time ZONE 4 — Mountain Time ZONE 5 — Pacific Time ZONE 6 — Yukon Time ZONE 7 — Hawaiian Time To change the default time zone display, depress the Time Zone button. The number “02” will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Check the time zone setting for your local time zone. If you are Eastern Time Zone but setting is for Pacific Time Zone, then the difference will be several hours. Check your manual for proper setting.
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
I had a similar problem--no manual--but found this way to set the clock: 1) Be sure colon is flashing (unplug and replug) 2) Press the 10 HOUR/MIN, 1 MIN, 10 SEC/MIN, and 1 SEC/MIN buttons until the correct time displays. 3) Press the CLOCK button. Hope this helps.
How
to Change the Time Zone Press and hold the “-“ button for 3 seconds the letter P
will appear where the seconds are than press and release the “-“ button until
the correct letter for your time zone appears.The four time zones are P is Pacific, M is Mountain, C is Central and E
is Eastern Time zone.Press the SET
button to confirm or leave the setting to confirm and exit automatically.
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time
zone. If you live in the Eastern Time zone, there?s nothing else to do. Your
interruption.
ZONE 1 ? Atlantic Time
ZONE 2 ? Eastern Time (Default Setting)
ZONE 3 ? Central Time
ZONE 4 ? Mountain Time
ZONE 5 ? Pacific Time
ZONE 6 ? Yukon Time
ZONE 7 ? Hawaiian Time
The number ?02? will appear on the display
Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time
interruption.
ZONE 6 ? Yukon Time
Eastern Time
