First you remove the four knobs. After the glass maintop assembly. After that you will be able to clear see all parts including the element. Element is secured on the metal base and you should remove the wires first. Just take notes where each cable goes or you can take a photo to have it as a reference if you forget anything. Put all back together in reverse order and is ready. We have here the parts layout which will help you understand what is in you electric range. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=215800
Hi, you can view the manual for the GE Radiant Cooktop HERE
Hi...thanks but I need instructions on how to replace a burned out element. The OWNER'S MANUAL does not address this issue.
Thanks, David
[email protected]
I own a GE Radiant Cooktop. The left rear element is burned out. I need instructions on how to replace it or the entire Service Manual.
The part # is JP340BOC1BB.
Thank You.
