THE PART NUMBER HAS BEEN CHANGED IT IS P200-97
YOU CAN GET IT AT
HERITAGE
THE PHONE NUMBER IS 1-800-458-5593
You can only get it, by buying 200 from the manufacturer in CHina. OR you can get s Substitute part from Senasys in Wisconson. It is a Temperature Switch (350 L-2169 Open 350 Close 100 (+/- 10). It is a slightly bigger part, so you're only going to be able to install 1 mounting screw. Make sure it is mounted though so it doen't move and short out. Make sure all contact are not cross touching each other. It will fit in though and it does work.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
