Right after you press the start (power on) button for the notebook, tap the F9 key about once every second (do NOT hold the button down, as this will cause the machine to think there is a problem with the keyboard, and generate a 303 KEYBOARD ERRER) to take you into the system repair subroutine. There should be an option for "Factory Restore", however, you'll may need to dig a little to find it. Once you select the factory restore option and the process begins, DO NOT interrupt the restore process at ANY time!!! (also, be sure the notebook is plugged in to an AC outlet, as battery power may not be sufficient for this task, and the restore process goes fast on AC power anyway.
