You need to remove the exterior washer case to access the internal components on these model washers. The following link explains step-by-step how to access and/or replace a lid switch:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
The lid switch on this particular model is located under the top washer casing along the LEFT lid hinge. The lid hinge acts as the actuator. Usually the switch either comes loose, or you may need to bend the hinge rod actuator slightly so that it will toggle the switch when the lid closes.
If the switch is found to be defective, the part number for a replacement is 8318084. You can purchase replacements at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites listed have exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. For reference, type your model number in as "110.27831600" when searching for parts. If your model number does not appear on all the websites I have listed, use the the part number from the Sears website as your search criteria. The model number may not always cross reference, but the part numbers will.
If you have any questions, please post back and let me know. I hope you find this information helpful.
First unplug unit ..You will need a fairly stiff putty knife, you need to remove the upper console to gain access to the lid switch, push your putty knife straight in towards the back of the unit one at a time under each end cap of the control panel afteryou have popped loose the clips you can flip open the console and you will see the lid switch on the back left hand side .Its just snaps in place..Tip before doing any of this make sure the 2 small screws are completely tight that attach the lid to the left side hinge because this is also the arm that actuates the lid switch .. Writing it out makes it sound way more complicated than it is ..Its really a 5 minute job Good Luck
