Car Audio & Video Logo
Posted on May 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a 91 Jaguar XJS and need to know how to find and enter radio code. Thank you Don Houchin
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on May 21, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
22
Helped
1063238
Points
7105
Hello Don
The way to recover the radio code is to remove the radio and copy the Serial Number off the radio's label, then take it to a Jaguar dealer's Parts Dept. where they can get the code.
It usually starts with a letter followed by about 9 or 10 numbers then a space and 4 more numbers...the last 4 are the code.
Thank you for using Fixya, and please "Accept" the solution if it helps you in any way.
Cheers!
IrishDruid
  • Anonymous May 22, 2008
    Well, you can remove it this way:
    Knobs should pull straight
    off. Under them is a locknut with two notches 180 degrees apart.
    Unscrew both lock nut, remove the time panel. Now there should be four fasteners in the corners, Push in the pin to release the tension on each
    and slide the radio out. You will need new pins.
    If not, try slipping a thin plate like a putty knife down both sides of the radio. This releases spring clips and the radio should slide out.
    If you are in Europe, you can try this link:
    http://www.skjagtech.co.uk/support-pages...
    (they charge you for this service)
    Hope that helps!
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1147022
Points
9064
Nice..had a 76 Jag, myself...can you let me know which radio you have installed on that model, please?
  • Anonymous May 21, 2008
    and, where was the Jag made?
    Nice, ID>.and what if this fellow, like most sane folks, or those who have had Jags, know how weird it is to extract anything from a Jag console?
    you guy, you...
3helpful
2answers
I need the radio code for a recently purchased XJS Jaguar
As an anti-theft deterrent, Jaguar began installing radios at the end of the Series III era which required the input of a security code to enable the radio to function. While coded radios are a pain, our experience is that they have drastically reduced the radio theft rates in major cities like Atlanta.
When cars with coded radios were first sold, the owner received a pair of plastic cards, about the size of regular credit cards, listing the radio code. When used Jags trade hands, these cards are forgotten and usually are not passed on with the car. And then when the battery dies and is replaced, the radio insists upon being recoded before it will work again.
One tip is that the dealer technicians frequently would write the radio code under the hood of the car in marker. There are also reports that the radio code was on a paper label which was stuck to the underside of the hood when the radio was installed. So if you do not have your code, it is a good idea to look under the hood for the paper label or for a hand-written four or five digit number. You may get lucky; we have known owners who found their radio code in this manner.
To recode the radio once you have the code, turn the car’s ignition on and then turn the radio on until the word "code" is displayed on the radio faceplate. Enter the radio code slowly and deliberately, firmly pushing on each button. If you have entered the correct code, after the last numeral is entered the radio will beep and then begin to play on the last station selected. If the radio has been uncoded for a long time, or if power has been removed from the radio for a long time, sometimes you will be unable to enter what you know is the correct radio code. In these cases, leave the radio powered, with "code" displaying, for an hour or so and then try to reenter the code. The code will usually take after doing this.
It is not possible to guess at the radio code and to just keep trying combinations of numbers until stumbling on the correct code. The radio will accept only three coding attempts before it locks up for an hour. Then you have three more attempts before it locks up for eight hours, then three more tries before it locks up for 24 hours, and so on. The times indicated may not be accurate, but the process is correct as described.
If you cannot locate your radio code, either from the previous owner or from the car itself, the only way to get the security code is to pull the radio to retrieve the radio’s serial number and to request the code from your friendly Jaguar dealer. All dealers have the ability to retrieve these codes, although they will vary in their willingness to do so for individual owners.
Where do i find the coolant temp sensor in my 89 xjs v 12 jaguar also the map sensor
images for coolant temp sensor 89 xjs v 12 jagua
Jaguar XJS Coolant Temperature Sensor - YouTube
? 5:39
www.youtube.com/watch?v=awd2f3HL7N4
Jun 15, 2014 - Uploaded by Abe Caleb
Working on the Jag and bringing it back from bad mechanics that have bad skills. If you do not know how to ...
Where is the key code on a 1994 Jaguar XJS located?
use the vin number and go to a jaguar dealer it will cost you about 65.00 I had the same problem. The vin number is on your title and your registration
Need help finding the colors to install radio its for a jaguar xj6 89
should be the same
http://www.modifiedlife.com/1989-jaguar-xjs-car-stereo-installation-diagram/
3helpful
Need radio code for 1993 xjs
the only way to retrieve this code is to call the dealer(they may have you come in) and prove ownership with registration and VIN and they will give you the radio code and process to reset. if you still have the owners manual, many people write the code somewhere in it just in case.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
