I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
I believe that if you reach a busy signal, you can hang up. The conference should ring you back and the rest of the conference will be there.
Here's what the documentation shows from within the help of a 3300 ICP/MCD...
a 5303 is to be treated just like a 2500 series set...
2500, 5302 IP
Phone, SUPERSET 401, SUPERSET 401+, and SUPERSET 4001
telephones:
To form a Conference when a two-party call is already in place, or
to add another party to an existing Conference:
Press Flash or flash the
switchhook.
Dial the number of the next party.
Wait for an answer.
Press Flash or Flash the
switchhook.
Dial the Conference Call Feature Access Code.
To Leave a Conference:
Hang up.
2500 telephone:
To split a Conference and speak privately with the original
party:
Flash the switchhook.
Dial the Conference Call Split Feature Access
code.
