Press and hold Volume up and Power button at the same time until you boot into the Android system recovery.... Choose Wipe data/FactoryReset with your volume keys and then press the power button to confirm.
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
Press the Menu key twice.
Scroll to Options and press the Navigation key.
Scroll to Security and press the Navigation key.
Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
When the box next to the menu item is ticked (V), the selected data will be deleted.
Highlight the field at the bottom of the display and key in blackberry
Scroll to Wipe and press the Navigation key to restore the factory default settings.
Follow the instructions on the display to set up your phone and prepare it for use.
You will likely have to reset your tablet to it's factory settings using the key sequence.. it'll mean you'll have to re-load your data and programs but you'll have your tablet back. Been there more than once... Oh well.. here's the procedure:
Press both the volume up key and the power button key to turn the tablet off completely. Once it's off, press down the power button and the volume key together. Release the power key and hold the volume up key until the "Factory Reset Menu" appears. It looks kind of like a robot with it's chest hatch open. Use your volume up and down buttons to move the selection to "Factory Reset" and press the power button to select it. The tablet will reset itself and you'll be back to a brand new tablet.
Before doing the master reset and format Nokia E7, you have to backup any important data
Battery Nokia E7 should full charge
Turn Off Nokia E7
Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
The process will do format to factory default Nokia E7.
turn off your SAMSUNG GALAXY MINI. press and hold POWER button + ENTER button (HOME KEY button) for reset menu. select FACTORY RESET using VOLUME KEY DOWN BUTTON button. Press the ENTER BUTTON (HOME KEY button to RESET. warning: all your phone data will be lost! God bless.
Hi angie_baby07, since you are using a Lenovo netbook without the DVD drive. you can perform the One Key Recovery or in other words, factory reset.
Turn off completely your pc.
then beside the power button at the upper left corner of your keyboard, there is a button with a u-turn symbol on it. Please press and hold the button for 5 seconds. Then wait for the One Key Recovery button. Then Press the One Key Recovery option once it loads. Then press restore to factory default. Then click next and then click start.
Hi, Not every function on the TI83Plus calculator has a dedicated key, or is accessible through a key sequence. Among the keyless function is the factorial function.
To access the factorial function
Through the catalog of commands: press [2nd][0] (CATALOG) and scroll Up till you reach the exclamation mark !
Press [MATH]. Use right arrow to highlight PRB menu. The factorial function is the 4th in the list.
Syntax
Type the number and use one of the foregoing access methods to echo the exclamation mark on the home screen and press ENTER. Ex: 12! =479001600
The largest number that you can use with the factorial is 69.
