Locks & Locksmithing Logo
Posted on Sep 23, 2010
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but that doesn't work. Can't find the manual eighter. Please help or let me know how to reset the code. I'm thinking someone at the store might have change it from the default. Thanks, Tom
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10504
Points
20
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
  • 1 more comment
  • dsawkins Sep 07, 2011
    I have a Rona with two remotes which I cannot seem to code. Also the manual specifies step 14.2 as absolutely necessary but there is on step 14.2 in my book. It ends at 14.00! The master lock works good.
  • Anonymous Nov 27, 2011
    Try this link and click the tab for the manual..http://www.shopkeylesslocks.com/LockStat...
  • Anonymous Aug 29, 2012
    Is there a way to delete one of the code? I also have another kind of problem with the exact same lock.. Sometime, the knob gets kinda sticky, like there was a notch in the system. It will do that a couple times, then get smooth again...
Resetting Master pin on rona Electronic Deadbolt lock
Google
Adding a PIN:
make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock
Rona collection door lock
I Bought a Rona keyless door lock about 10 years a go.It is broke its life time warranty. where can I get it replace.
1helpful
2answers
I bought Rona Collections Electronic Deadbolt. My problem is when my door is locked and when you pressed padlock button without entering your pin code the door will unlock. Any solution to this problem?...
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
I have a Rona keyless lock with two fob remotes which I cannot get to work. The master lock works fine. There also is reference to step 14.2 in the instructions but there is none in the booklet with that...
I've located a number that you can call for RONA customer service:
1-866-283-2239
8 a.m. to 8 p.m. (Eastern Time)
Monday to Friday
I believe this is the link to RONA where you find your lock featured for sale:
http://www.rona.ca/shop/~deadbolt-digital-deadbolt-rona-collection-253947_locksmithing-accessories_rona-product-line_shop
Unfortunately, there is no downloadable instruction manual to download, ETC., so call the number and begin the process--I hope you get an answer without too much telephone runaround!
Good luck!--and please give feedback if this helps you toward a solution.
2answers
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
I am trying to reset the password for the Rona deadbolt but cant find my manual. i need the steps
I looked for a Rona manual.
The Rona website has advertisements for air-travel miles, so I guess the page doesn't have enough space to show product manuals.
The descriptor-page uses 99 words to describe the digital deadbolt in tiny print so there is no clue as to the operation of the product. Maybe they do that so you have to buy another deadbolt to get the instructions.
There is a 'contact-us' page that lets you fill out your personal information to share with them so you can receive further run-around. But wait, the form doesn't work because it doesn't accept postal codes. Wow, but there is a phone number 1-866-283-2239
https://shop.rona.ca/member/customer-service
Best of all, the Rona website solicits their customers to become a dealer for this poorly represented product.
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Top Deadbolt Locks & Locksmithing Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
