SOURCE: Philips CAR 400 code
This code will not be available for free from anywhere on the Internet as it is not in the available Philips database.
Main Dealer or a Decoding Service who will connect it to a computer to read/recode the code memory chip (EEPROM)
SOURCE: I need the code for my philips car radio. MODEL: CAR400
Please
check your Serial Number again to make sure it is correct.
If
it is correct , then unfortunately your code will not be available for free (or cheap) from anywhere on the Internet as this Serial
Number is not in the available PHILIPS database.
It
requires access to the original manufacturer`s database which is only available
from your Main Dealer .(and a few of the larger Professional Radio Decode Specialists)
Otherwise
try a Decoding Service or your local Car Radio / Audio Shop who will
electronically "read "/ recode the memory chip (EEPROM) using a
laptop and specialist software.
SOURCE: My radio wait up radio code. I don't remeber this
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST A BRAND NEW QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on
ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
SOURCE: unlock car stereo
Sorry....this code will only be available from your Main Rover Dealer or by using a Radio Decoding Service as it is not in the available database
Remove the radio from the dashboard.
Then post all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Further useful information can be found here
Numbers on the 22 DC 511/00
9022215100900 and 00192139006104
