The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
SOURCE: CAN NOT OPEN DEFAULT USER NAME / PASSWORD, ADMIN/ADMIN
On the back of the device, There is a small reset button, Hold that with a pen for 30 Seconds, that will reset everything, Including that password.
SOURCE: D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
SOURCE: i have Dlink 615 model router. i reset one time
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
