Question about Lanier UNKNOWN
How do I remove the hard drive from a Lanier LD328c. This needs to be done for security reasons.
  • 904 Answers
You should contact a Lanier or Ricoh service technician to remove the hard drives for you, but if you have to do it yourself the hard drives can be removed by unscrewing and sliding out the controller board (on the right side of the copier). The hard drives are connected to the controller board by three screws and four connectors.
Posted on Dec 31, 2010
SOURCE:
How do I Remove the hard drive from Lanier printer model number LD445C
It is located behind the panel where your Ethernet cable plugs in. The easiest way is to remove the rear panel. Then remove the metal panel. From there you should be alright on your own.
Oct 14, 2014 | Ricoh Lanier Ld445c Ld435c Ld430c Magenta...
Lanier 335c toner won't load
If the toner hopper assembly is not broken the mylars inside of it have fallen off over time. The toner supply unit needs to be replaced.
Apr 25, 2014 | Lanier Ld328c Ld335c Type R1 Toner Black...
Not want to read the new toner
Very, very common issue on these normally related to a problem in the toner hopper assembly itself.
Feb 08, 2014 | Lanier Ld328c Ld335c Ld345c Black...
I can't seem to remove my hard drive. can anyone help me?
1. Unplug laptop from AC power.
2. Remove battery; Look at laptop manual if you don't know how to do this.
3. Flip the laptop over so the bottom of the laptop is facing you.
4. There should be a rectangular bay on the back of the laptop that houses the hard drive. See picture for an example. Your laptop will likely look different but the picture should help give you an idea.
5. Remove the screw(s) that secures the plastic plate covering the hard drive bay; there's usually only one or two screws to remove.
6. You will now see the hard drive. Look for any screws that are securing the hard drive to the laptop. Remove the screw(s). Not all laptops will have screws securing the hard drive to the laptop but some do, and I'm guessing this may be your problem.
7. Slide the hard drive horizontally away from the interior (middle) and toward the exterior (outside) of the laptop. The hard drive is plugged into the laptop and this action will unplug the hard drive.
8. That's it - you're done. Just reverse the steps to replace the hard drive.
Good luck and thanks for using FixYa.
Mar 17, 2011 | Computers & Internet
We have a Lanier Copier Model 5635 and we need to know if saves PII information on a hard drive before we can remove it from our office.
yes it does. the hard drive is located on the left side in back of the machine, It is easy to remove. If you are trading it out, you can either remove it yourself or have a service rep remove it.
I have done that several times for customers who do not or can not allow hard drives to leave their presence.
Feb 22, 2011 | Ricoh FT5832 Copier
How do you remove the hard drive (memory) from a Lanier model 5635 copier?
FT 5832 is analog copier their is no hard drive for analog it just present digital copier.
Jan 07, 2011 | Ricoh FT5832 Copier
How to reboot a computer with erasing hard drive
You need to get a little more familiar with terminology; 'reboot' simply means restart and while PCs start from the hard drive, erasing the drive means making the hard drive momentarily empty of data or system files.
Did you mean 'reformat?' This can make the drive empty of any recoverable files if done properly or, if done with the quicker method, it simply makes the file names different and unusable meaning the content can be recovered if desired.
If you are trying to destroy existing data but want to preserve the operating system, there are numerous free utilities that will do that securely and remove sensitive material.
I use this one for secure deletions, it's pretty simple and easy to use and can make any data totally 'gone' by several different methods.
Eraser
May 19, 2010 | E-Machines eMachines Desktop PC
Lanier ld045 hard drive problem, what does this mean and how do you fix it?
How do you know you have a Hard drive problem? and if you actually do, then replace it. It's just a regular IDE hard drive
Dec 05, 2009 | Lanier Office Equipment & Supplies
Lanier UNKNOWN Logo
1,110 people viewed this question
Top Lanier Televison & Video Experts
gggg
Alun Cox
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
