SOURCE: Seal/Gasket kit for Powermate 4-Gallon air compressor Model #VP0000401
Just some information that may lead you to parts, The compressor sold thru Lowes (Kobalt) must be the same mfg. because the parts look like they would interchange. A trip to Lowes may verify. Maybe they have a compressor with bad motor for your parts. Good Luck
SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
SOURCE: dewalt D55155 air compressor regulator installation
The d55155 unit suffers from regulator problems due to weakness in the design of the manifold. The manifold parts are very light duty metal and will break during installation if not carefull. If you can return the parts to dewalt it may be more efficient to to use a generic pressure regulator from www.grainger.com for about 20 bucks and mount using a couple of 1/4" tees directly off the pressure switch. Remove the hose from the pressure switch that feeds air to the manafold . Install parts so that the quick disconnects, guages and new regulator are accessable from the side. It will not be pretty but problem will be solved for long term. We repair other brands that come with control panels using the same method. Pressure regulators built into a manafold will fail. For demanding customers we have recreated the manafold using 1/4 pipe fittings and refit the gauges and grainger regulator into panel.(lots of work) But leave the safety unloader at the pressure switch. If all you need is a good functioning compressor same time and money and mount to side. Good Luck and email if you have questions or other issues with your dewalt.
SOURCE: Hobart mixers A120 & A120T.. has an oil leak.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
