Fuel gage 4 lpg isnt working. always shows emty when its just been filled up!! any ideas
How do i find out whats wrong with my gas gage on my 2000 ford taurus?
Behind the Guage there is an anti-rocking amplifier/whatever ford wants to call it this week.
yours is probably shorted.
It cost me a bottle of Jim Beam for an answer from an ASE certified mechanic on that one.
But it's fixed.
There is a sending unit in the tank this has probably clogged or wore out it has a filter on it, with gas debries this will make your guages stop working correctly
replace sending unit by dropping tank with gas out of tank and then pull out sending unit replace with new one
SOURCE: Fuel Gauge Not Reading
you might wanna check the contact on the floater i had that problem so i just bent the contacts closer and that worked for me
SOURCE: 2001 hyundai sonata 4 cl can't pump fuel into tank @ normal rate
The sending unit in your tank is going bad replace it.
SOURCE: Fuel gauge not give proper reading.. register full
Sorry to say,but the fuel sending unit is the problem,the fuel tank will have to be lowered out of the vehicle to replace the unit.If the fuel sending unit is not available by itself you will have to replace the whole fuel pump assembley.
SOURCE: Gas gauge does not read
The most probable cause is a faulty or improperly installed fuel level sending unit inside the fuel tank. The second most likely cause would be the gauge itself not able to make the full swing.
i can not fill my gas tank
I HAVE SAME FUEL GAUGE PROBLEM I HAVE REPLACED NEW FUEL PUMP,GASOLINE TANK AND YET FUEL GAUGE DOES NOT WORK.GAUGE MARKS PAST FULL.THE GAUGE HAS MOVED ONLY TWICE BUT QUICKLY GOES BACK UP TO FULL .
