Roland Dp 2 Damper Pedal Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was looking at a 2nd hand KR 103 to buy. If while playing notes the damper pedal is pressed all sound is muted. Is there a function switch or something that needs swiching on to get it to work? The owner is a school.... no one there knows how it works.
Fred Yearian
Level 3:
  • Roland Master 5,603 Answers
  • Posted on Sep 23, 2010
Fred Yearian
Roland Master
Level 3:
Answers
5603
Questions
Helped
2247423
Points
16162
Please note that ROLAND equipment USUALLY uses Normally closed (electrically) damper pedals for their equipment. Most other brands use normally open ones. If you are using a non-Roland pedal, that is likely the problem.
SOME PEDALS require opening and changing a wire (involves soldering) to match the unit you are plugging into. A very few have a switch on them to allow changing polarity.
A few synths, like the Yamaha Tyros have a built in setup screen where one can select the polarity of the attached pedals.
1helpful
I have a roland ep97; i've tried several pedals, played with the polarity; even found the pedal DP 10? But notes continue to sustain when damper is released. Could it be the keyboard?
First you need to make sure that the keyboard is programmed to accept the DP-10 as factory default and then that the DP-10 is working perfectly. There is a case where the DP-10 action switch is activated directly, in this case the sustain does not stop and you need to change the micro switch of the DP-10 pedal. It has already happened to me and I replace it by adapting another micro because Roland does not support you and wants you to buy another DP-10.
1helpful
I have a Roland Kr-3500 that has a distortion sound after the note is played. Sounds like a reverb/distortion. The unit sounds fine when in DEMO mode and also using line IN sounds fine.
I know nothing about music, and I don't play piano, but I have played with these when they first came out. I was manager of a public hall and a shop brought a load of them for demonstration. It sounds like an Effects setting and I know that is one called 'Leslie', which if I remember correctly is the effect of a speaker spinning in a speaker enclosure.
Here is your manual
http://www.synthmanuals.com/manuals/roland/kr-3500/owners_manual/kr-3500_om.pdf
Service Manual and a link to Roland, to ask them direct.
Roland KR-3500 Service Manual, Analog Alley Manualswww.analogalley.com > osccart > product_info
Product: Roland Digital Intelligent Piano, model KR-3500. Service Manual , First Edition. Contains/Contents: specifications location of controls
Support - Manual Archive - Rolandwww.roland.com > support > manual_archive
HP-3500S Owner's Manual · HP-3800 Owner's ... KR-1070 Owner's Manual · KR-117 Owner's ... KR-4500 Owner's Manual · KR-4700 Owner's Manual · KR-4700 ...
Roland USA
5100 S. Eastern Ave.
Los Angeles, CA
90040
US
Phone: 323-890-3700
Fax: 323-721-4875
Hammond sk1 foot switch is set to toggle Leslie effect between fast and slow. How do I change it to act as damper sustain pedal or other function such as glide?
Thre is a sustain pedal jack next to the foot switch jack. The pedals used are different. The foot switch is a latching switch, the sustain pedal is a momentary.
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
6helpful
3answers
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
2helpful
2answers
When I plug the pedal in and play, the music is constantly sustained without me pressing the pedal. Do i need a new pedal ? Is the problem within my Roland ? Please help ! - I use a Roland 700 GX. -The...
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here:http://www.akaipro.com/mpk49 Please let me know if this helps.
Nov 30, 2009 • Akai Music
1helpful
Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
Metal Pedal mutes my guitar.
Sell the pedal and get a digitech, or convert it into a looper pedal.
A really bad 'off key' note
what is make and model? I have owned several keyboards, with 2 of them Korgs in which I would connect a damper pedal. I noticed that when I help down the pedal, after so too much input within the cpu of the keyboard, it would 'short-circuit' and sound like I had played an 'off-key'
If you have been using the damper pedal, and even if you release a little on up on it, but not all the way, the 'off-keys' will still sound. I must always make sure the pedal is placed in a position that my leverage action of my foot will completely 'release' the overtones still being processed by the keyboard (whether they're audible or not)
Jan 11, 2009 • Music
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
