Whenever I plug a usb 2.0 compliant device into my t40p (running xp pro), i get a message that "this device can perform faster if plugged in to a usb 2.0 port" I have updated the bios, uninstalled and reinstalled the ports and hubs (and updated the drivers), installed windows xp sp3, oh, and verified that the machine does actually have usb 2 ports.but my problem doesn't solve.do you have ny ideas?
This is because you are plugging in a USB 2 device to a standard USB port, or a USB 3 device into a USB 2 port. The computer is just telling you that if you upgrade the hardware, the device will work faster. Its more of an information message than an error. Your device should still function fine.
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
That means that the USB drive that you have on your computer is either on the USB 1.1 driver and you have to update it or your computers USB is not capable of USB 2.0 speed. First thing you need to do is find out the model number and brand of your motherboard. Then go to the manufacturers website then look at the manual for the board to find out if you have USB 1.1 or USB 2.0. If you have USB 2.0 then download the latest drivers for your board. If you only have USB 1.1 then your only options is to buy a USB 2.0 to PCI card that will give you USB 2.0 or just stay with the USB 1.1
After following the on-line instructions I replaced the USB cable that came with the Maxtor with a difrent one and now the drive works as it should. I do not know what the problem is with the original USB cable.
Thanks for the follow-up
Glenn Alford [email protected]
