SOURCE: no sound
Use the CD that cam along with your pc or motherboard and try to install sound in it.
SOURCE: No audio
hi here is the link you need just copy and paste into top of the browser
http://driverscollection.com/?file_cid=388241075640e4766a71576556a cheers where the http is just to make sure lol
SOURCE: booting problem
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
SOURCE: I need a manual for the Jetway V266b rev.3
Here is the link:
http://www.machspeed.com/manuals/VIPER/V266B.pdf
Adobe reader will have to be installed on your PC.
Hope this helps
Chris
