Televison & Video Logo
Posted on May 21, 2008
Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
I just purchased a Toshiba model# D-VR610KU VCR/DVD Recorder and trying to connect this thing has proven to be over my head.
It doesn't come with a tuner and according to the manual you can use your satellite box as a tuner, and I have a dish network box, so I swear I connected it exactly as shown in the manual and the only thing I can get a signal on is the satellite tv -- there's no picture or sound for the DVD/VCR. I even tried omiting hooking it to the satellite at all and it's not giving me a picture or sound. My VCR that I'm replacing with this thing had a tuner and I was able to connect the satellite to it just fine. I also have a beastly entertainment center that makes it near impossible to get behind and see the connections on the TV.
I don't know if this is a question that is able to be answered over the internet but I just thought I'd run it past anyone that's willing to listen. Does anyone make housecalls? Hah, hah.
  • 8 more comments
  • LRJPGMS Jun 09, 2008
    I have the Toshiiba D-VR610K7 DVD/VCR Recurdor. When I use the S-Video connection it does not show up as a input dievice. Help
  • Anonymous Jun 26, 2008
    I have the same system, Toshiba D-VR610KU but a Samsung Plasma TV. I Have connected with the RCA jacks. With the recorder off I receive the picture and sound from the dish receiver but when I turn on the recorder first I get the Toshiba wecome screen and then it goes blank and shows DV/No Device.
    [email protected]
  • chevrojoe Jul 31, 2008
    I have run into this problem also. I bought the toshiba and when it arrived I started hooking up. Low and behold there is no place to hoop the cable up. I read thru the book and it says I need an external tuner. Can't seem to find out what that is. Radio shack guy said he had just the thing. Turns out he sold me an RF Modulator. Not what I need. I even took the book with me but he sounded so sure that I just bought it and realized when I got home that it wasn't what I needed. Anyway, can anybody give me pointers on how and where to get this external tuner. I'm not doing well. at it
  • Anonymous Aug 08, 2008
    I too just purchased a "like new" Toshiba model# D-VR610KU VCR/DVD Recorder Combo & discovered I need an external tuner. I do not have one. The seller "Tool Guru" on Amozon.com won't take this machine back--but did tell me I needed a cable box or satellite link from the cable company & that box or sat.link is used as an external tuner.
    EJG
  • Anonymous Sep 20, 2008
    Have the same combo. The Dvd player works, but the VCR doesn't. There is a coaxial connection on the back of the combo and 1 on my cable box, but a standard coaxial cable doesn't work. Is this my problem?
    My vcr doesn't work. I think the problem may be with the coaxial cable running from the recorder to the cable box. The cable I have doesn't fit. Do I need a special digital cable? I have digital cable box..
  • olgagabe Sep 20, 2008
    I can't get the vcr to work. It might be the coaxial cable as it doesn't fit going from the combo to the digital cable box. Is there such a thing as a digital coaxial cable? thanks
  • Anonymous Sep 23, 2008
    I have a digital converter box. I still can't get it to show pictures from the TV. I'm so confused. Help!
  • olgagabe Sep 28, 2008
    I have the same combo, hooked up to an LCD tv and cable. Only the dvd works. can't get the vcr to play or record. any suggestions?
  • jadedalex
    jadedalex Oct 16, 2008
    Hey Jillber,
    I think I am onto something....there is an RCA adaptor that you can screw into your coaxial cable that will make the connection to your Toshiba.
    As I stated in my other comments, I don't know WHY Toshiba didn't just supply a coaxial connection on this DVD recorder/VCR.....the coaxial connection, that little pin that fits into the input on most VCRs (mostly known as 'ANT' short for 'antenna') has been abandoned with this unit and most new units.
    I guess it was just too easy. You'd plug that little pin into your TV and you'd get cable. Duh.
    You can get this adaptor at Radio Shack, hopefully. It screws into your coaxial cable and has the male adaptor that slips into the female input of your 'coaxial' input of your Toshiba.
    Good luck,
    Tom
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2365
Points
0
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
Toshiba DVR19DTKB2 Combi VRC/DVD player/recorder. How can I get copy of a manual for it please?
Question edited for a lot more clarity.
TOSHIBA DVR19DTKB OWNER'S MANUAL Pdf Download
ManualsLib https://www.manualslib.com > ... > DVR19DTKB
View and Download Toshiba DVR19DTKB owner's manual online. DVD/Video Cassette Recorder. DVR19DTKB dvd vcr combo pdf manual download.
Toshiba DVD VCR Combo DVR19DTKB2 instruction ...
Manuals Online http://www.manualsonline.com > dvd-vcr-combo > ins...
Apr 13, 2013 - instruction manual for Toshiba DVD/Videocassett recorder DVR19DTKB2- or instruction on how to copy from video to DVD.
TOSHIBA DVR19DTKB2 Service Manuals
Service Manuals https://www.servicemanuals.net > TOSHIBA-DVR19D...
Most of our service manuals will include disassembly instructions, schematic diagrams, parts lists, exploded views, troubleshooting, wiring diagrams and much, ...
US$16.99
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
1helpful
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
4helpful
Can you record a dvd from vhs on this system ?
No you cannot - This is a DVD *PLAYER* / VCR combo - which means it features a DVD player & VHS recorder in one - you cannot record onto DVD - You can however watch a DVD while recording your tv program on the VCR.
I hope this answers your question.
If you want to convert your VHS to DVD you will need to purchase a standalone DVD recorder - I personally do not reocmmend the DVD recorder / VCR combos - or you can use a HDD/DVD recorder which stores recordings on a hard drive and later you can burn them on DVD, they allow editing, more flexible recording options, etc
We recently purchased a toshiba recorder/vcr combo d-vr610 and it plays dvd's with no problem but we tried to watch a video and we couldn't get a picture. I can't find the manual to see what I need to do....
The DVD will play through component, composite, or HDMI, but you have to hook the VCR up separately with component cables - look at the back of the combo, you'll see where it says "VCR". That's where the cables have to go. Pretty silly, but I had the same problem, and this is the only solution I could come up with.
Cannot record onto DVD
we are borrowing the unit and do not have the user manual. we cannot figure out how to record a self made vhs to a dvd. how do we do it? please help, its for a project that is due tomorrow.
Need code number
I tried a Panasonic 4-unit universal remote (about $8 at Wal-Mart), and the code that works for it (sort of) is 0998. I say "sort of," because on the DVD side, you can only advance forward and backward from one chapter to the next (you can't "scan") and on the VCR side, you can't fast forward or rewind at all. So I'm returning the remote and looking for a "real" Toshiba D-VR610 remote. But I suppose this universal remote could be better than nothing, at least for the DVD functions.
Toshiba D-VR610KU
All coaxial inputs or outputs on any unit is the screw-post type. The female part is a standard coaxial cable that slips onto the posts on the unit. Are you trying to convert Coaxial to RCA?
RCA recorder just purchased
I ckd the internet and found that this recorder had a lot of problems and solved the problem by returning it to the store.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
