Issue With Pre initial Rom Fail To Voltage Routine Check Cause... Static on The Chip Unit Posibility Security Relais Wont click On.. Do do so check for Fuse or red push botton over load security Braker at the back of your unit.. if your fuse is good Well Open the case and surch for more fuse inside of the unit Make shure the unit is unplug from the wall...Then check The voltage on the Transformer to make shure you have the right voltage then check The Regulator The Coil and Capacitor If your not shure Well send it to a Reapair Shop it your best choice Amp cant be dangerous for hazard shock....Good Luck
