Www.scribd.com/.../Sony-Service-Manual-TV-KV36XBR450-Chassis-DX1A -
www.scribd.com/doc/.../Kv34drc500-Da4-Service-Manual
Above are your service manuals. Please use these to troubleshoot and hopefully repair your issue.
Whenever a PSU shuts Off automatically, well this is due to the "Protection Circuitry" detecting a Fault, that is potentially so severe that, the set needs to be shut down, then, immediately, to avoid a fire, and explosion or both. (Often it is caused by the component overheating, and going short circuit.)
Now it is THIS "Cause" that must be found, and repaired, also any damage done by that "Cause" too.
Now irrespective of whatever the Symptom is , one MUST always start at the Power Supply, and make sure this is 100% correct, as if this isn't NOTHING else can ever be. then once one is sure that it is OK, then work out from there to try and find the actual "Fault".
As an aside here the reason that the Red is more redder may indeed be because the Power supply is providing too much voltage/current and it is being overdriven, this and the shutting down are no doubt related.
Again use the service manuals to troubleshoot and replace the board that seems faulty.
All repair data is in the manual as are the parts numbers too, more importantly.
It is my professional opinion though, with a set like this, rear projection, that it should be attended to by a Sony professional, i would advice you to first ask for a "Quote" before allowing any repairs to proceed, this way you can then decide as to repair or replace. I say this as many times with these sets, the costs can ramp up, very quickly, and make any repairs un-ecconomic. in these cases, it is better to put the monies that would have been spent on repair towards a new set, with a full warranty.
