Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt Logo
Posted on Sep 22, 2010
I need a replacement thermostat for a Patton model POH2501 oil-filled radiator heater.
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Does not heat up. Is there a way of opening the radiator?
Oil heaters produce no fumes or flames and feature whisper-quiet operation. Because the oil within the heater never needs to be replaced, oil-filled heaters are maintenance-free. In addition, these types of heaters are compact and portable - allowing you to carry them from room to room. Many also feature carrying handles or a set of casters for easy mobility
some of these types of heaters have a hole with a plug, that allow you to add oil, but few of these are in use today. so this being said it is most likely the heating element is failing to fully heat up the oil. parts may be found, if researched in detail on the net
also be known that the electrical componets are most likely to fail befor the oil evaporates. so look at all overheating controls and so on.
good luck,
2answers
Lakewood space heater thermostat source
No I never had any luck and the parts likely 1/2 the cost or more of a new one at wal mart and the heat element would still be old too
Patton POH2520-U heater not working
I have a RD125T heater. At first it would run for a while and shut down. Turn it off and back on it would do the same. Now when it is turned on it acts as if the switch was being turn off and on. Sometimes the heater will fire for a second then shuts down. Most of the time it just shuts down, Forest
Not heating
Sounds like either the thermostat or the element. If you hear a clicking when you rotate the thermostat you can assume that it is working. My advise is to replacethe heater. The element is sealed inside the oil chamber and the thermostat will cost almost as much as a new heater, sorry.
3answers
Patton POH2501
take a hole punch and knock a hole in each end, one on the top, one on the bottom and drain the oil into a 2 litre plastic bottle. Now you can recycle both!
Top Patton Electric Heating & Cooling Experts
Paul Carew
john h
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
