Mitsubishi WS-55613 55" Rear Projection HDTV Logo
Posted on May 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HELP I have a MItsubishi HD1080 series 55" rear projection tv. Recently, I have had problems where the TV won't turn on. THe green light blinks, but then the TV powers off. HELP please.
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on May 21, 2008
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1722222
Points
23750
How many times does it blink it should blink a two digit code. let me know the sequence of blinks as it should be a self diagnosis code
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Tv problem
can you tell in what patter does the light blinks??
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
1helpful
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
8helpful
2answers
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
TV wont turn on, the power light turns green for a second then blinks three times and turns off?
That blinking light represents an error code,give Mitsubishi a call they will help you troubleshoot and diagnose your problem and if needed help you set up service. 1-800-332-2119 Good luck !
3answers
Turns off
No I do not have an answer yet
Dont have a remote
A green blinking light usually indicates an internal problem. The service person can use the pattern of the blinks to determine the problem.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
