OUR FRONT LOAD WASHER MODEL# WBB4500G0WW GOES THROUGH THE WASH CYCLE BUT AFTER THAT IT WON'T GO THROUGH THE RINSE AND DRAIN CYCLE. WE UNPLUGGED THE WASHER FOR AT LEAST 20 MINUTES AND PLUGGED IT BACK. WE SET THE DIAL TO THE RINSE CYCLE AND THE RINSE INDICATOR LIGHT STAYS ON AFTER A WHILE AND THEN SHUTS OFF BY ITSELF WITHOUT GOING THROUGH A RINSE CYCLE TO DRAIN THE WATER. PLEASE HELP!
MY BAD, IT'S NOT A FRONT LOADER...IT'S A TOP LOADER.
JUST FYI!
I'VE ALSO MANUALLY DRAINED THE TUB FULL OF WATER BEFORE UNPLUGGING THE WASHER. TRIED THE WASHER CYCLE AGAIN, THIS TIME A SMALL LOAD, IT FILLED UP WITH THE AMOUNT OF WATER NEEDED, WENT TRHOUGH THE DELICATE CYCLE, ONCE IT WAS DONE WITH WASH CYCLE, IT WOULDN'T GO THROUGH RINSE AND DRAIN CYCLE ONCE AGAIN. THE CYCLE LIGHT WENT TO THE RINSE CYCLE, BUT WAS ON FOR A MINUTE AND THEN THE ENTIRE MACHINE TURNED OFF WITHOUT EVER RINSING OR DRAINING. PLEASE, ANY SUGGESTIONS AS TO WHAT IS CAUSING THIS MALFUNCTION IS MUCH APPRECIATED.
MY FIANCE AND I CANNOT GO ANOTHER 2 MORE DAYS WITH THIS DILEMMA AND I WON'T PAY $200 TO GET IT FIXED. ON A VERY TIGHT BUDGET AND LIMITED INCOME.
THANKS!!! HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
oldfixer, what did you mean when you said, "also ck control bd for connections most likely suspect all ck ok is control bd itself?"
Can you be more specific please? Thanks!
stops and hums when the rinse and spin cycle comes, leaving it filled with water
had the machine on super capacity setting and the water over flowed onto floor. didn't have a large load in the machine at the time just had it on the that setting. after cleanup and drain excess water from under the machine the washer wont engage into the spinning phase. can here the usual noise but no spinning. turned machine off, unplug for several hours, and still nothing. please help
it will run water but it want wash rinse and drain
my ge washer/dryer combo finishes the wash cycle (if I don't have to hit start in the middle of it sometimes), then shows steady green ON light, but Rinse light flashes. Sometimes need to hit start button to get the rinse/spin cycle going
