Honeywell 5804 Ademco Wireless Security watch Logo
Posted on Sep 22, 2010
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Oct 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
8817
Points
29
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
2helpful
I have a AW60448W stopwatch that I can't get the alarms to turn off.
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: [email protected] if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Dec 28, 2010 • Watches
1helpful
9answers
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 • Watches
I have a square Freestyle watch. It keeps beeping, can't trn off
You can try taking the battery out and waiting a minute or two then replace but you should probably have a watch maker/technician "AC" or clear the watch. This involves resetting the circuit board and only takes a moment. I would also have them reseal the watch and pressure test it as Freestyle's are made to be in water and you will want to maintain the water resistance.
5helpful
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 • Watches
11helpful
2answers
I can't turn the alarms off on my Casio GW-330ca
Setting CASIO G-Shock Watch 1) Home City
3) Adjusting hands
4) Alarm set/on/off 5) Snooze 6) Hourly Chime A --- B ( ) Button reference C __ D
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
5) Snooze (SNZ) Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To stop any alarm, press any button. To cancel next snooze, Press C and go to either the timekeeping screen or the snooze alarm screen.
6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
1helpful
I have the wrong day of the week, when I set the date.
The day of the week will be right after setting the year, month, and date. Adjust with step 2) from timekeeping mode (where time, date, and day can be toggled with button D).
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A --- B
C __ D
Press C until timekeeping mode is reached (high beep).
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
22helpful
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
8helpful
I cant set the digital time in casio illuminator
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
2helpful
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
2helpful
Watch
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Top Honeywell Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Honeywell Watch Expert? Answer questions, earn points and help others
