Some of them TDs has a float which triggers a kill switch to stop the dryer if the water level exceeds the level and would overflow. Perhaps your float is stuck. I have not had the priv of working on one of these yet as they are not in my area. But I have been studying em.
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Common faults - 1 Theheating elementscan fail(meaning open circuit) 2 There arecut-outs (T.O.C's)thatmight need resetting 3 Thethermostats (stats)can tripout or burn out (meaning opencircuit) 4 Moderntumble dryers also have sensors andpcb's (Printed circuitboards)thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is. 5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
