Question about Xerox DocuColor 3535 Copier
Have error 010-349
It sais on my command workstation close door
    President:
  • 2,072 Answers
That is the front thermistor on the fuser has gone bad.Most likely need to replace the fuser module.
The part number is 008R12904.
You can look in the fuser and see if there is something stuck under the front thermistor.
But be careful that fuser is extremely HOT.
Posted on May 20, 2008
Great!
Posted on Dec 18, 2008
SOURCE:
I am getting a 'disk full' message on the Fiery. How do I delete it?
TROUBLESHOOTING
This chapter provides troubleshooting tips.
Troubleshooting the Fiery
Startup diagnostics are described in the documentation for service technicians. Contact your
authorized service/support center if you see error messages while Command WorkStation is
starting or if the Fiery does not reach the Idle state.
Runtime error messages
For error messages related to canceling jobs and printing, including the Disk Full message and
alerts to load media, see Command WorkStation Help.
For error messages related to the copier, see the documentation that accompanies your copier.
You can turn on PostScript error reporting as a print option from Mac OS applications.
Printer not found
Most failures to find a printer on the network are due to conflicting or missing name or
address settings for the Fiery. You must type names in specific places. The required names are:
•TCP/IP host name (also known as the DNS name), which is defined by your organization.
Type the host name as the Server Name in Fiery Setup.
•Remote printer (internal machine) name. Use one of the following:
print
hold
direct
NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you
must reconfigure one of the utilities on each workstation. http://swdownload.efi.com/ftpvefigs/9019710383/2822679259/9432346727/7795362481/Configuration.pdf
Dec 12, 2015 | Xerox DocuColor 242-252-260 PS
We need to get the printer to recognize the network server name or IP address. At present it says "Unable to connect to (DC-260-795622). The server name or IP address may be invalid.
Ensure that all your network settings on the printer are correct, especially the DNS settings. Are you able to ping the printer from a workstation? Maybe you have a bad cable connecting the printer.
Jan 21, 2015 | Xerox Office Equipment & Supplies
The ntvdm cpu has endountered an illegal instruction. Cs:0df1 IPL01f6 OP: ff ff 00 00 ff
SYMPTOMS
When you attempt to run a 16-bit program on a computer running Microsoft Windows NT 4.0 Service Pack 3, the program may quit immediately, or you may receive the following error message:
Hidden Console of WOW VDM
The NTVDM CPU has encountered an illegal instruction.
CS: 04c3 IP:3937 OP:c71c 9d 37 00
Choose Close to terminate the application.
When you click Close, you may receive several similar error messages.
CAUSE
This behavior can occur if you use an incorrect version of the Command.com file. For example, this issue is known to occur if you use a Command.com file included in Microsoft Windows 95, dated 7/11/95.
RESOLUTION
To resolve this issue, replace the Command.com file in the Winnt\System32 folder with the same file from another computer that is running Windows NT Workstation 4.0 or Windows NT Server 4.0, and then make sure that there are no Command.com files dated 7/11/95 on the computer. You can also replace the Command.com file on the computer with the same file on the Windows NT installation CD-ROM.
PROPERTIES
Article ID: 245184 - Last Review: November 1, 2006 - Revision: 1.1
APPLIES TO
Microsoft Windows NT Server 4.0 Standard Edition
Microsoft Windows NT Workstation 4.0 Developer Edition
Jul 22, 2014 | Dell Computers & Internet
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
Command Workstation for fiery x15
xerox.com look for dc 3535 in support and drivers and the new command workstation is in there
Oct 27, 2008 | Xerox DocuColor 12 Printer
First 30 pages of a print run after 24hrs idle are blank
don't upgrade the xp, it runs a limited version to ensure that the command workstation works ok. A reload is probably in order to start again. Any updates can generally be found on the xerox website, and installed via command workstation
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
1,129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
