Check the float to make sure it moves freely up and down, and it should click when it moves. Remove float and clean around the float tube-you may need to do this from below, through the access panel. Use white vinegar to scrub the float and shaft assembly. Turn on the dishwasher to see if this fixed the problem. If not, it may be the float switch. If you are handy with electrical repairs, turn off the power to the dishwasher, pull the dishwasher from the wall and remove the back. Remove the wires from the terminals on the float switch-use masking tape to identify to identify terminals,noteing which belongs where.Remove old switch and replace with the new float switch. You will need the serial number, model number and make of your dishwasher to order the new float.
Hi
When the Dishwasher won't fill you'll need to
check for the water inlet hose, the water inlet valve and the float switch
assembly. When the water fills your dishwasher, a float rises along with it. As
the float reaches a certain threshold level, it shuts off the flow of water,
thereby preventing a leak. Sometimes the float can get stuck in the wrong
position in your dishwasher, and it can prevent your dishwasher from filling.
Sometimes it can happen due to float valve and on other occasions due to float
switch. Inspect the water hose coming to the dishwasher for any blockages. If the
hose is not clogged then check the water inlet valve for any clogs, if the
water will not even fill for few seconds then certainly the water inlet valve
is bad and should be replaced. You can also use a multimeter to check
continuity on inlet valve. If you don't get any value on the multimeter then
you'll need to replace the water inlet valve assembly. However, if the valve is
fine then the float switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
