Posted on May 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MHC-RV5 Hi , I have problem with my Sony Hify mini component system MHC-RV5. Do you have the repair manual for this or similar products.. regards Jerry
  • jerryns May 21, 2008
    The problem is there is no sound from Speaker. When i checked i am not getting out put from pre-amp section. Power amp is working fine.. Other issue , there is a 12V unreg goes to the mother board (main brd), but this seems to be 24V instead of 12 V... So my assumption is that there is some problem with this regulator and Microcontroller is not issuing command to Pre-amp IC.
  • jerryns May 24, 2008
    Any help ?
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on May 20, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563176
Points
12312
The repair manual can be purchased from Sony. What is the specific problem. Perhaps a manual is not needed.
Dan
  • Dahoo Lahmar
    Dahoo Lahmar Jun 02, 2016
    the code is c81 and there is no sound at all help please
Sony MHC-RV5 Stand By issue
Could be an open internal fuse or power supply failure
2answers
Sony MHC-S3 Mini Hi-Fi component system
Correct the laser is not reading the disk. Cleaning won't help. Usually not worth getting repaired as a similar new unit will cost about the same!
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
1helpful
2answers
Owners manual for a Sony Mini Hi-Fi, component system,MHC-GX250
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX250
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
5helpful
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
