Hi, just visit ebay web site and search for item #230735864835. this is a convergence repair listing,don't buy a repair kit if you don't know how to solder or you'll damage your board. so try this guy and let the professional do the Job done right for cheap.
The convergence amplifiers are probably bad and maybe some other small parts. On this particular model Mitsubishi changing the convergence amplifiers is extremely tough even for the best technicians. I have seen one like yours that I got in for repair this year that had been messed up by another technician. I charged accordingly to do both repairs... the damage the inexperienced technician did... and the original problem. This repair should cost between $340 and $390 (mostly labor) depending on the region/cost of living.
You have tools like a soldering iron,desoldering pump and solder?Can u do basic soldering?The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced to solved the convergence problems.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop will cost u $300-350 for parts and lobors.
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide? Follow this link to download a pdf version of the operations manual.
Any shop with experience should be able to replace the convergence ICs which are the likely problem. This type of repair will cost less than the boaqrd replacment and won't require a conmplete reconvergence adjustment. The parts cost around $25-$40 each (there are 2).
I would look for someone that is able to change the ICs rather than the entire board.
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Yes, it can be repaired, replace convergence out chips (two ICs) on main board. If you are not comfortable with TV repair or have no experience, call local tech to fix it. Cost of repair would be $180 or so.
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
