Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
I have a kohler a112.181 faucet.. I am experiencing very little water pressure and a slight leak. In faucet handle. The sprayer seems to work ok. I need to know how to take faucet apart to find problem and fix. Any help?
    New Friend:
Having the same problem and just found the spec sheet. Going to try to repair today. Hope this helps!
http://www.us.kohler.com/onlinecatalog/pdf/1013943_4.pdf
Posted on Aug 06, 2011
  • bobisha La Femme
    bobisha La Femme Feb 16, 2015
    Please stay on Topic of Make and Model
SOURCE:
Kohler sprayer with forte single handle, will not spray well. When sprayer is on the flow to faucet cuts off but there is only a small amount of water coming out the sprayer.
Check to be sure the hose isn't kinked somewhere below the faucet. If there aren't any kinks there is likely debris stuck behind the nozle screen, remove it and clean it- or your handle mechanism is broken. Replacement handles and hoses are fairly inexpensive if you need one they're easy to find at most big hardware stores or on Amazon
Sep 05, 2013 | Kohler Kitchen Faucets. Forte 1-Handle...
How can i disassemble the sprayer handle on my kohler a112.18.1m kitchen faucet
1-800-4KOHLER
http://www.us.kohler.com/us/static/helpTopicsHelper.jsp?helpId=728
Aug 27, 2012 | Kohler Plumbing
Kohler style k12172 fairfax when i use the side spray there is very little pressure & the hose and sprayer are new and the hose has no bends in it.
you have an other part that went bad. Inside the faucet there ins a part called a devertot that is in the body of the faucet. This little part move the water from the main spout to the hand held sprayer.
You have to remove the handle and the spout. pop it out pop a new one in and you are good to go.
Glad you came to us for help. your rating us help us know how well we have done
Tom
Sep 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
I used different length supply lines because th hot water line was a little short. Would this cause the side sprayer to move when the main faucet is turned on or the faucet head to drip?
No the length doesn't matter. When you turn the faucet on, you also fill the hose to the sprayer, and it may expand slightly, causing the sprayer to move a little. Is the drip from the end of the spout at the aearator? or is it around the faucet lever. If it is the lever, you should be able to tighten it slightly. If it's the end, make sure your aearator is clean.
Jul 18, 2010 | Kohler Fort© Single Lever Handle Kitchen...
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
5,229 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
