My Vizio TV has the same problem. Changing the volume on the Cable Box has no effect. Turning off the TV's SRS TruVolume "feature" greatly reduces the hissing but means that the volume is radically different depending on each input.
Do you have a cable box connected to it? I'm sure you do .. You might have the TV or the cable box at max volume ..
If you are using the TV as the main volume control try to lower the volume from the cable box, maybe to mid volume.
If you are using the Cable box as the main volume try doing the opposite from the above..
Hope this helps.
