My GAMETIME watch has a back which just pops off. Once in the battery compartment, you will see plastic disk, with a molded frame. This just simply pulls off, and is not secured in place. You should not have to pry it.
Once this is removed, the battery is revealed. My model takes a SR626SW. To remove the cell, use something small to get under the exposed side. You should be able to pop the cell out without much force.
Before you replace the battery take this opportunity to clean the rim where the backing was. Carefully install the new cell, and replace the cover.
Simple...just did mine Use a quarter in slot on back of watch and turn it slightly to the left...then use a knife gently to pry the back piece off and remove old battery...replace with new battery and snap backing on...use a quarter and turn to the right so the little arrow is pointing at 9 o'clock
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
SOURCE: removing the back to change battery
I had the same problem.
Remove the watch band.
I had to cut the plastic band away.
The plastic was was easily cut.
The back plate of the watch simply snaps away.
No screws.
There are four corner snaps.
Get under one and the others will pop off.
SOURCE: I can't seem to remove
its probably a screw on back that needs a special tool to open it. but even if you do open it you will not be able to seal it properly
SOURCE: How to Remove Watch Case to Replace Battery
the anser to the question is you need a special tool to open the watch as this is a screw back and you can buy this from Watch repair dealer from about £10
