Please do upgrade your mp460 printer drivers also
Testimonial: "Thanks this is what I needed to know I was missing the scanner software ...I didn't realize the printer drivers didn't include this."
Sujimanfsu - normally not, but maybe its software problem. Try something basic like MS Paint you can find it in Start menu in your windows. Try scan some picture in that software.
But I think it will call your drivers, so maybe it will same.
If not help, un-install ALL drivers for your printer/scanner and install it again. Install ALL Drivers NEW from site. Printer driver, Scanner Driver..etc
Thanks Rodier this is what I needed to know I was missing the scanner software ...I didn't realize the printer drivers didn't include this.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
What does mean "no longer is able to scan". If you try to scan something with your software, what appear? some error? or nothing? And which software are you using to scanning? Maybe that software is not compatible with Windows 7.
Thanks for the reply. The scanning functionality seems disabled...it seems to go through the motions on the printer display but the last button press would normally start it up and send to pc....I'm getting nothing after the scan button press. No errors at all either. Do I need some scanning software other then just the drivers for the printer?
The solution was that I was missing the mp460 scanning software. Merely the printer driver installation wasn't enough.
