Hi, I bought a Mitsubishi HDTV integrated 1080 in mid 2004, a few weeks back while I was watching tv, it switched to a black screen, as if it was changing inputs on me. I would turn it off and on again. It would work for about 5 minutes then back to black screen. I turned my tv off for 3 weeks and now when I plug it in it the green power light just blinks, nothing else. Can you please help? what should I do? I spent way to much money for this to be happening.
Thank you sooooo much.
Naomi
My tv is a mitsu 65 in ws65869 greenlight is blinking can some one helpme get a t dmboard thanks
The manual says that when the power is turned off you must give the TV a minute or so for the bulb to cool down and you are not supposed to turn it back on until the green light (power) turns off.
Mine does that every time I turn it off
Remove the lamp and see if it is broken(instructions in owners manual)
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
I was watching tv last evening then in the morning i tried to turn the TV on an all i get is a green blinking light. I also un plugged the power and then tried to reset. I also plugged into a different outlet to make sure it is not because of low voltage. i am getting 115v Help
video slows down, changes res, turns off, then green light blinks for a while before I can turn it back on. this happens too frequently to stand.
cable went out last night this moring turn tv on all i get is green blinking light. thats all?????
mitsu 55 in WS and green blinking light does not stop. Please help!
We had a brief power surge, the TV shut off now the green light blinks and the reset button doesn't help. WE unplugged it for several hours, still blinks. Help anybody!!!
Thank You SOOOO much.
I have the never ending blinking green light.
Green blinking light. First occured was able to fix by unplugging TV and waiting five minutes to plug back in and turn on. Now no matter what I do the blinking light greets me. Spoke to Mitsubishi and they say send in the chasis and a thousand dollars, after 6 to 8 weeks all will be fixed.
