Question about LeapFrog Leappad Plus Writing
My leappad plus writing won't respond when i press the go puttons on the books.
  • nikkiarnold1
    nikkiarnold1 Dec 04, 2012
    Mine doesn't respond either - and the recorded voice prompt keeps skipping and repeating words or phrases. Did any of these solutions work for you? I'm not sure if it's the stylus that isn't working or if it's the entire system, so I don't want to go buy a new pen if the actual machine itself is broken.
  • nikkiarnold1
    My Leappad Plus Writing won't respond either - and the recorded voice prompt keeps skipping and repeating words or phrases. Did any of the suggestions work for you? Since I'm not sure if it's the entire system or just the stylus that's broken, I don't want to buy a replacement pen if it isn't going to work anyway.
    New Friend:
  • 6 Answers
If it does power up, and you are unable to get only the Go button not to function, there could be 3 problems
1. the cartridge is dirty
2. the sytlus is bad
3. the sensor membrane is wet or bad.
Clean the cartridge or try another book.
Replace the stylus.
Dry out the leap pad (this is a last resort. place the leapPad in a sunny window for a day, standing upright and open (remove batteries).)
If nothing else works, you can find another leapPad at most thrift stores (that works!), for about $5-$25 (any model, but you might not get a lot of model choices, but some even come with books and cartridges you might not have!)
Take a book and a cartridge with you, maybe even batteries, and ask the store if you can try it before you buy it (they will usually let you test it)
Posted on Oct 01, 2010
    New Friend:
My Leappad PlusWriting stopped recognising the GO symbols on all books as well. The internal electrical connections for the left-hand page are held together by a plastic clamp which appears to bend up in the middle over time. Adding a small bracket above the original clamp (to straighten it out) sorted the issue out. This appears to be a design fault.
Posted on Apr 27, 2013
6ya staff
SOURCE:
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
Won't set up
Try turning off your wifi and skip the wifi setup and create a profile. Then install Leapfrog connect on PC and update the Leappad. This should then resolve your wifi connection issue. It worked for me when I had the same issue today.
Dec 25, 2013 | LeapFrog Leappad Plus Writing
Leappad 1 screen has a white dot
Contact the website. You can't be the first or only person this has happened to.
Jan 20, 2018 | LeapFrog Leappad Plus Writing
LeapPad start-up screen frozen
Same problem here my daughter is flipping out!
Mar 12, 2012 | LeapFrog Leappad Plus Writing
LeapPad stuck on Leap Frog screen.
I have the same problem. did you ever find an answer???
Feb 17, 2012 | LeapFrog Leappad Plus Writing
I have a LeapPad model 57 that has 8 books with it and only 2 will work. I know they go to the LeapPad system I have because on the books that go into the LeapPad show the same picture as the LeapPad...
Given two sets S and T we declare S<T.if there is a mapping of T onto S but no mapping of S onto T is possible .prove that if S<T and T<U then S<U.
Nov 11, 2010 | Computers & Internet
I thought the batteries were being drained over night each time I had to replace them. Then after replacing them about four times in twenty four hours, I repeatedly pressed the power button and eventually...
Sounds like a stuck pen button or the pen wire is pinched (look in the battery door at the pen wire).
Although it very well could be something (spilled) in the power button.
Don't take it apart too far.. once the membrane on the touch screen is disturbed or taken apart, it'll never work right again!
For a whole replacement leapPad, try a thrift store. I see them all the time, all models, under $20, sometimes under $5. (I have a 4 year old son and he destroys everything!)
Oct 01, 2010 | LeapFrog Leappad Plus Writing
Leapfrog Leappad Learning System book. Regardless of what book/cartridge is inserted, it only plays "Lil's Loose Tooth" the book not in the system. We've turned it off, replaced the batteries. I don't...
Try cleaning the other cartridges contacts with alcohol and Q-tip. The major problem with the leappad is that the cartridges are failing after the warranty period is over.
Jun 11, 2010 | LeapFrog LeapPad Learning System:...
Replacement Leap Pad Pen
Hi, I have found this pen on www.leappadpen.com
I hope that this helps?
Regards
Nov 19, 2009 | LeapFrog Leappad Plus Writing
LeapFrog Leappad Plus Writing Logo
2,545 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
