Question about Just Wireless Nokia Swivel Car Charger
When I plug in car cell phone charger Just wireless SKU 03047 it blows the fuse!
2 Suggested Answers
SOURCE:
SOURCE: What type of fuse does my just wireless car
It uses a mini 2Amp cartridge fuse, as a workaround, one may simply use a single strand of very thin wire... or even a very thin strip of aluminium foil wound onto the Body of the fuse.
Posted on Feb 08, 2010
My 2006 VW Beetle continuously blows the Accessory fuse utilized for the power port for the cigarette lighter and underneath the center console. The proper fuse was replaced. Only my phone plugged in when...
Hi Troy,
Without seeing the ports of the car and the plug of your charger, it would be difficult to diagnose with any certainty. I do have a suggestion however. Your note suggests that other devices do not cause the fuse to blow when they are used - it is only the charger for the phone. Since the charger works in other cars, it is probably not an overload condition due to a defective charger, but more likely a mismatched set of contacts between the plug and power port in your car when the two are mated. Some cars have slightly different sized power ports that can be either too tight or too loose for some plugs. Too tight ports could be causing parts internal to the charger's plug or car's power port to short together and blow the fuse.
We can get around this be using a different plug. The easiest way is to find a cord set that will plug into your car's power port and provides a simple extension for 1, 2 or 3 outlets. These can be found in auto parts stores and the automotive departments of stores like K-Mart, Sears, etc. Some examples look like these:
Insert the plug into the power port - and check that the fuse does not blow by checking the fuse - not by plugging something into the the outlet on the cord. If the fuse remains good, then it is safe to assume that the problem with your charger and the car's power port has been eliminated, and the car's power is available at each of the outlets of the new cord.
Try plugging the charger into the outlet of the new cord. If all is well, the charger should be working as expected. What we have done is removed the charger / car power port combination from the equation, by providing a different combination to do the same thing - but without the same physical connection that causes the fuse to blow.
You could achieve the same results by changing the charger plug under the right conditions - but many chargers now a days have circuitry inside them that change the car's 12 volts to something different. If you can find the voltage out of the charger and are able to match it with another - it must be the same voltage, polarity, current and phone power connector of course - it should work, too. You must be absolutely sure of the power requirements and your rewiring - if not, stick with the addition of a cord described above.
I hope this helps & good luck!
Aug 27, 2012 | 2000 Volkswagen Beetle
Fuse # 4 2002 f 150
Stop plugging into the console power point with whatever it is that you keep plugging in that is blowing the fuse. The truck is not the CAUSE of the problem. Your defective accessory is. (cell phone charger, radar detector, GPS unit...whatever it is...?)
May 12, 2012 | Ford Cars & Trucks
MY CIGERETTE LIGHTER WON'T CHARGE MY CELL PHONE PLEASE HELP!! I DON'T KNOW WHAT TO DO!!
The body fuse is probably open(blown) The fuse paels are under the hood drivers side another fuse panel is under the rear seat (deivers side) both panels on the inside cver identfy what fuse is for some chargers may blow this body fuse you may have to get a adapter to plug into the lighter then plug phone charger into adapter
Aug 18, 2010 | 2000 Cadillac Eldorado
It blows the fuse everytime I put the cell phone charger in. Going to change out lighter and can't figure out how to get behind the dash on 2002 Sebring
most of the time its the cell phone charger that is the problem. the ones with the cheap plug that has the fuse inside it are the worst. try the lighter in it, if it works without blowing the fuse then you should get a new charger or replace the plug with a good one
Mar 30, 2010 | 2002 Jeep Wrangler
My lighter on the console and inside the console are not working-what should I do? I cannot charge my cell phone either.
Usually the fuse blows because of faulty cell phone chargers. Check the fuse and change it if necessary and also check your charger for your cell phone. It might be blowing those fuses!
Feb 25, 2010 | 2004 Pontiac Grand Prix
What type of fuse does my just wireless car charger sku No. 03206 use?
Feb 08, 2010 | Just Wireless Nokia Swivel Car Charger
My charge port in my 2006 cadillac cts repeatedly blows the fuse. How can I fix this?
Does the fuse blow every time you plug something into it? I guess what I'm getting at is it possibly your phone charger only, or does the fuse blow when someone else plugs thier charger in (different charger)? I guess if the fuse blows, no matter what you plug into it, I would suspect the charge port itself. Does it seem like it's loose in it's mounting bracket? You may have to replace the port.
Jan 03, 2010 | 1995 Cadillac DeVille
Cig lighter works 4 cigs but wont charge satnav however much i twiddle about with it, help!!
Try checking the fuse inside the charger. Ths may be blown. Have you tried another charger in its place ex. cell phone or radar detector? If works for the cig lighter should charge.
Nov 05, 2009 | 2001 Ford Focus
Cig lighter, radio, etc wont work after plugging in cell phone to charge
it sounds like you blow up a fuse,check your fuse box,
check your manuel for locations
gl G
May 04, 2009 | 1998 Toyota Camry
Just Wireless Nokia Swivel Car Charger Logo
173 people viewed this question
Top Just Wireless Cell Phones Experts
Marvin
Marvin
Are you a Just Wireless Cell Phone Expert? Answer questions, earn points and help others
