Question about Acer 22" X223w LCD Monitor
My monitor hibernates after a few minutes..how do I reset it so it won't do that? How do I set the brightness?
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Power Options
Change the setting for the monitor from a "few minutes" to "60 minutes" or to "never".
Posted on Sep 20, 2010
6ya staff
SOURCE:
Emachines e191w tft lcd flat panel monitor
you might try going into the display settings and making sure that first, your resolution is set correctly for the monitor and secondly that all the settings to put the screen to sleep or hibernate after so many minutes is set to never on both battey powered and wall powered.
Aug 23, 2013 | Computers & Internet
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
My hp vs19 computer screen was working fine when i shut down and now it won't power on at all.
HPw1907 monitor on "built up" computer. Processor is AMD Sempron 2800+(800)S754, Video card is Navidia, Albatron GF FX5500. Operating software is Windows XP home, SP 3.
Factory brightness setting is much too high. Each time that I restart the computer after shut down, I must reset the brightness setting. Immediately after startup, brightness is OK; after a few seconds, the monitor goes into auto adjustment, and goes back to factory setting and I have to reset.
I will appreciate any help that is provided.
Dec 03, 2009 | Office Equipment & Supplies
Brightness pop-up window on screen
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
Brightness and contrast light keep coming on
The up/down button on your flat panel is stuck. Please contact Hannstar Technical Support to have the monitor replaced if its still within warranty.
May 19, 2009 | Computers & Internet
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
Acer LCD Monitor
It is with your system. You might have hibernation enabled and many advanced video cards cannot recover from a bios or control panel timed hibernate. Start by using the Power Options from the control panel. Select "Always On" for everything and select the Hibernate tab to be sure that the Hibernate check box is not selected. Make sure you APPLY the settings. If the problem goes away, you can tweak the settings to get the power savings features you want without losing your system..
Dec 11, 2007 | Acer AL1711 17" LCD Monitor
Open Questions:
Display not working, power button LED turns on blue for 1 second and won't turn on again I've searched the web as well as this site and can't find my exact issue anywhere. I hope I'm not duplicating this question though. My X223W monitor is pushing 6 years old. It was working perfectly 4 weeks ago before a 1 week trip. When I returned, I pressed the power button to turn it on. The power buttom LED simply turned on blue and then turned off after 1 second. I get NOTHING on the display itself, not even a flicker nor the Acer logo. Pressing the power button again got nothing - not even the 1-second power button light. I unplugged the monitor, plugged it into a wall outlet it was plugged into a power strip the whole week I was gone, tried the power button again, but got NOTHING. Not even the 1 second power button LED. Here is what I have tried to fix this: 1. Tried 3 different power cables that are confirmed working - nothing. 2. Tried 2 different outlets that are also confirmed working - nothing. 3. Tried unplugging the monitor, holding the power button for 10 seconds to do a reset - nothing. Although, this did accomplish restarting the cycle in which I am able to get the power button LED to do its 1 second turn on/off again. Still nothing on the display, though. 4. Took apart the monitor to look at the power supply board capacitors. None of them were blown, bulging, or looking strange at all, but I ordered a kit online to replace them anyway. When done, I triple checked my solder points, cap orientation, uF size of each cap, and re-connection of all cables - all good. But, the symptom is exactly the same. Same 1 second power button LED turning on/off with nothing on the display. Because of the age of the monitor, I think I'll likely just buy a new Acer. But, I'd love to fix this one eventually so that I could maybe end up with two displays. Is there another component I should be looking at that might cause this? Should I replace the entire power board? Is in an inverter? The logic board perhaps? Any advice would be welcome.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
See all Acer 22" X223w LCD Monitor Questions
Acer 22" X223w LCD Monitor Logo
57 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
