Toshiba Satellite A205-S5804  PC Notebook Logo
Posted on Sep 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using My Toshiba Satellite A205 laptop then suddenly it turns off - then i switched it again, the logo appears, then it turns off again, i switched it for the last time but it didn't turned on, i've checked the connection to the power - there is no disconnection ... i thought the problem was the charger then i brought a newer one, but when i plugged it didn't work... what would be the problem?
Anonymous
Level 3:
  • Master 2,567 Answers
  • Posted on Sep 21, 2010
Anonymous
Master
Level 3:
Answers
2567
Questions
0
Helped
671044
Points
7153
1. It's possible the AC adapter died while you were working on the laptop. The laptop was running until you had charge in the battery and after that it turned off. Can you test the AC adapter? Make sure it outputs correct voltage.
2. It's possible that you have bad RAM module. Do you know if you have two RAM modules installed in your laptop? Try removing them one by one. If one of the modules is bad, the laptop should start when your remove it.
  • Anonymous Dec 15, 2010
    Check the system fan, it seems to be doing a self protecting shutdown due to overheating.
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
Toshiba satellite a205 will not turn on is it the power supply regulator on top rear panel?
Check AC power cord, use a different one, also plug into different outlet. If that doesn't work power switch is bad. Or something else is wrong.
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
1helpful
1helpful
Satellite a205 died. will not power up at all. 2
Go to the Toshiba web site. They often extend the warranty on laptops with common problems.
I have Toshiba Satellite P205 that has crashed
there is no reset button however you will need to switch off by simply pressing the power button depressed for some seconds then once the laptop switches off you will be able to reboot again.
Sattellite A205-S4577
pls restore ur system like this pls rate me FIXYA for this help
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
