You didn't say what model microwave you have, but most that I have seen have two separate circuits inside. One operates the magnetron (which makes the microwaves) and the other operates the other things like the turntable or the inside light etc.. It is quite possible that you have a problem in that second circuit. This allows the heating without the turning. To fix this type of problem, if indeed that is the case, requires some skillful trouble shooting inside the microwave which I don't recommend your try unless you are a skilled technician, because of dangerous voltages. Go ahead and post the brand and model number and I can be more specific as to what action to take.
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. If your microwave is counting down but will not turn on, this could be one of your problems to test... ... My Ge Jvm1540dm4bb microwave stopped heating & spinning so I opened it .... Microwave Oven Troubleshooting in MINUTES ~ STEP BY STEP ...
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
First of all, is the hole a factory one that you never noticed before? If so, leave it alone. I know that microwaves generate a lot interior heat and it needs to escape someway. Secondly, if it is not a factory made vent hole and you can't be sure if it caused from a lot of use, and if the oven still works fine, I would not worry about it if it were me.
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
