Likely, one of the transducers has drifted, and will need to be calibrated again. Consult the manual for your load management / controller for instructions on how to do this.
If this is happening regardless of boom position, you may be looking at a faulty extension sensor as well. Again, the manual will guide you through troubleshooting this.
If you are unable to make progress with the operator manual, then you will need to contact the manufacturer:
SkyAzul
200 West Main Street, Suite 2A
Middletown, MD 21769
Ph: (301) 371-6126
Fx: (301) 371-0029
They likely will want the records of the monthly maintenance checks as well, to see if there is a trend that can be tracked. In the mean time, that crane is a potential hazard, and should be tagged until the root cause is identified.
The problem posted is not clear enough, i will need more information as regards what the device you are referring to and what is the exact problem with the device.
Take care.
