Go to singerco.com and under customer support, look at frequently asked questions, they have alot info there. If, that doesn't work for you, call customer service at 1-800-4singer and they can advise you
Oh, been there. All you need to do is make sure that the thread reel is placed inside the netting, and that the netting is tight enough. There is no actual tension control other then the net sleeve. If its gone loose, just stitch up one side to tighten it and all your probs will be solved.
I bought a Futura CE200 machine. The software for the machine loaded fine as did the bonus designs but Auto Punch will not install. HELP!!!
In my Singer Futura CE250/CE350 manual, on page 38, there is a heading for "Straight Stitch With Auto Tie-Off Function."
It says:
1. Press the foot control and the machine will sew 4 stitches in forward and then 4 stitches in reverse and continue to sew in forward UNTIL the foot control is released.
2. Push the reverse switch and the machine will sew 4 stitches in reverse and then 4 stitches in forward and stop.
So, that would be a total of 8 stitches and makes me wonder:
Are you pressing the foot control and then RELEASING it?
Or, are you HOLDING the foot control down while you try to sew?
You must hold the control foot down while sewing.
