Question about Toshiba Televison & Video
Toshiba 32A42A - Menu options pop up all by themself, and the TV is making its own choices. Can this be fixed or do I call a Preist for an exercism or just get rid of it ?
    New Friend:
I had the exact same problem yesterday. It took me 1 hour and 45 minutes to find a solution. Here is the solution: It is not a stuck button or the television being 'posessed' that is resulting in the menu cycling. It is the fact that the television is in the DEMO mode. I was able to read the manual for this television online at the Toshiba website. On page 30 it states 'To stop the DEMO mode press 'recall', ''exit', or 'power'. Unfortunately the 'recall', and 'exit' button are on the original remote which I no longer have. The power button on my model is broken. I use the cable box to 'turn on the television'. In reality, the TV is never off, it is just showing a black screen when the cable box and DVD player is off. I suspect this defect in the power button has occured on other TV's experiencing this problem. I was able to push the broken power button to the inside and side of the television casing exposing a round circle that the power button pushes when the power button is not broken. I pushed this small circle to turn the television off. After about 5 seconds I pushed the button again and the television went on without the annoying menu popping up. Just unplugging the television and plugging the television back in does not work. You need to be able to push the power button, or one of the other 2 buttons on the remote previously mentioned.
Also on page 30 it explains how to activate the DEMO mode. It's not too hard to accidentally do, especially when you have kids pushing buttons haphazardly.
I hope this helps someone outthere in cyberspace! Kevin
Posted on Oct 17, 2011
SOURCE:
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
Connect sound bar to Toshiba 32C11OU
if this set has a headset jack u can use it
Feb 03, 2013 | LG 32 32LK450 32 in. LCD TV
My toshiba 32a42a power button is broken. Most remotes require the tv to be on so you can program it. How can i turn it on.
Contact the authorised service center for Toshoba to get a knob for ON'OFF switch to your TV. It is very easy to fix it.
May 06, 2012 | Toshiba 32AF42 32" TV
I have a Toshiba tv model 32A33 with a snowy picture. Is this something I can fix.
the remote must have a menu button. click on menu, and try and search for the picture option. once there, fiddle with the sharpness, contrast and less brightness options.....that should fix it.
Apr 26, 2012 | Toshiba 32A33 32" TV
Needs to be reset model 32a42a
Hello
There is no Factory reset option to reset all settings at one press with this TV. You have to enter each menu window and select the option reset, and press [Vol >] button. OK.
May 31, 2011 | Toshiba Televison & Video
Menu options pop up w/out me touching it. won't go away keeps popping up
Hello there id try Fully resetting the power to the unit if that doesn't seem to work check to make sure the menu key is not sticky if it is make sure the unit has no power and clean the menu key.
Jan 23, 2011 | Toshiba 32A43 32" TV
My toshiba 32a42a does not have a power button-how do you turn it on or off?Most remotes require the tv to be on so you can program it.
This set has a power button on the far right of all the buttons on the front. I looked at page 11 of the owners manual http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001840.pdf and it shows it very clearly. It looks as if the power button may be turned the opposite way from the other buttons. Thanks
Oct 29, 2009 | Toshiba 32AF42 32" TV
Its hard to hear the sound on the tv
your remote should have a menu button on it. press it. then look for an audio choice once in this option u can use the remote to search for an equaliser option
Jun 09, 2009 | Toshiba 34HDX82 34" TV
Tv problems
Have you tried taking the batteries out of the remote? Sometimes the buttons can stick.
Sep 12, 2008 | Televison & Video
Menu keeps popping up
Hi, heres your fix, very common problem usually caused (but not always) by using windex to clean the screen, replace the front control boards tact switches, replace all of them, part number is 23344443, end of problem :) BMW Rider
Jul 02, 2007 | Toshiba 32A43 32" TV
Televison & Video Logo
190 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
