Miele 24 in. G892SCU Plus Built-in Dishwasher Logo
Posted on Sep 20, 2010
I have a G 892 SCU Plus dishwasher and the intake /drain light has gone on
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 26, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1451
Points
I removed filter basket and under it there was a small chrome rod prodruding horizontally by about 3cm. I pushed this in and restarted the machine. Although the light flashed when I first switched on it went out when I started the prograamme. It is working fine now.
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
I need a diagram and fixing help for a miele G892 SCU plus. The dishwasher starts up with the intake draining light blinking and the saltpc light on. Then the start stop button turn green on. It sounds...
Water pump is for removing water. Check the fill solenoid for water getting into unit. If defective unit will not fill. If stuck in on position you will have flooding. Go to this site for parts help Search Over 2 1 Million Appliance Parts
Sep 03, 2017 • Dishwashers
1helpful
Miele g 892 sc intake/drain light is lite and unit will not operate
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Miele g892 scu plus, about 5 years old. when on, all it does is run some motor (humming sound) and flash salt or intake/drain. No program lights on. Sometimes can be reset so rinse light comes on and...
The water in the pan is what is causing the issue - need to find the cause of the leak - door seal or pin hole in a hose - possibly a leaking pump
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
2helpful
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
3helpful
2answers
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
