This is not a simple question. If you intend to run the full 100A and want to use 2core and earth pvc cable then you need 50mm squared cross section conductors BUT if the cable is long you need to consider the voltage drop and may need a larger cross section cable. If yor want to run armoured cable, you can use 25mm squared conductors,but again you must take length into consideration
SOURCE: Electrical cable size requirement
This is an answer to your question only. The safest thing to do is hire an electrician to do it. There may be factors you don't recgonize that a skilled eye would pick up on.
The proper size wire is #4 copper or #3 Aluminum. THHN is the most common and most versatile type in conduit. a #6 ground wire is ok. Stranded pulls a lot easier than solid and do yourself a favor and buy some wire pulling lubricant just in case.
Make sure to obey all manufacturer's instructions. If you use aluminum make sure to place anti-oxidation compound or Nolox on your lugs in the panel. Please write back with anymore questions.
SOURCE: titan 7000 generator...the generator is not
you know , i have helped several people on thire cars , i want a fix and you want money...not faiir at all....i thought this sight was a helpful sight...i see diferently now....thanks
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
