Xerox WorkCentre M128 Copier Logo
Posted on May 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RE : Xerox WorkCentre M128 016-782
Hello experts
I have a problem at work with my Xerox Work Centre M128 when I try to scan into a specific folder.
The error code is 016- 782
Can anyone help me please?
Thanks
Rika .
Post by tryit:
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
Initial Action Refer to BSD 16.1.
Power OFF/ON
Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
Hi
Thanks for answering so quickly
But I am no expert and I found your instruction very difficult for me.
Can you add more guide lines with no keywords (like BSD /…)
Did u add any documents to your post? My browser cant display any of that .\
Can I get the documents in links ??
So my problem is this – I need to scan to folder (SMB something???) .
I create a special user for the scanner machine with administrator authorization .
I create a folder on the server with authorization for everyone and the scanner user .
When I press "scan to SMB " on the machine and I fill all the fields that required then I press
start and I get the error code : 016-782
thanks a lot .
Rika
  • ccinziatarta Jan 28, 2009
    i've anothe similar problem:
    scan to network is work, but i want to use scan to home (homedirectory)
    scan to home is no work because @s2home template is no show
    on the printer's control panel.
    i've just enabled scan to home on cwis
    can you help me, please?
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on May 19, 2008
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1110230
Points
5835
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
  • Anonymous Mar 11, 2011
    Hello Pipla? Can you help me? How to connection in network Xerox M 128 printer? Thanks!!!!!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6736
Points
Reply
1 Related Answer
Anonymous
  • 2072 Answers
SOURCE: RE : Xerox Work Centre M128 016-782
1helpful
Need info on scan drivers for work centre pro m20i downloads
go to xerox.com you will find the drivers there for this machine.
Can I use Xerox Work centre XK50cx with Sony FS550?
Hi Jaci,
Copy and paste the link below into you browser and type in the word "scanning". With all Xerox machines there are many ways to setup scanning. Hopefully you can pick out the best way for you!
Best of luck!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_rpss_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_MFIJ_XK50cx):str(XK50cx),question=ref(ProdFamily):str(Prod_MFIJ_XK50cx),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:XK50cx,varset=prodName:%20WorkCentre%20XK50cx
2answers
Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
1helpful
2helpful
Xerox WorkCentre M128 - 016 - 782
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
