This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle
Before first use:
-Wash griddle in hot soapy water. Rinse and dry completely.
-Apply a thin coat of vegetable oil to the entire surface (front and back of griddle).
-Preheat your oven to 350*F. Place the griddle on the upper rack in your oven.
-Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing.
-The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle:
Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process.
DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use:
-To prevent rusting, store in a dry place and keep uncovered.
-After each use, clean with a stiff brush and hot water only.
-Do not clean griddle in the dishwasher.
-Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Some griddle seasoning instructions suggest cleaning the plate, then covering with oil & table salt. Put the griddle temp on lowest setting for at least 1/2 hr. Clean off oil & salt
SOURCE: New Griddle Hot Plate
wipe it down with olive oil and heat it up then let is cool completly and wipe again do this 4 or 5 times and you will be good to go
